Salta al contenuto principale
Protocol Dronium Two Rechargeable Battery Replacement
Cosa ti serve
  1. Protocol Dronium Two Rechargeable Battery Replacement, Rechargeable Battery: passo 1, immagine 1 di 1
    • Turn the drone off by moving the selector switch to the left.
  2. Protocol Dronium Two Rechargeable Battery Replacement: passo 2, immagine 1 di 1
    • On the underside of the drone, gently pull the battery compartment away from the drone.
    • Press down on the camera as shown to get a better grip.
  3. Protocol Dronium Two Rechargeable Battery Replacement: passo 3, immagine 1 di 2 Protocol Dronium Two Rechargeable Battery Replacement: passo 3, immagine 2 di 2
    • If the power cable of the battery is connected to the drone, remove it by gently pulling it out.
  4. Protocol Dronium Two Rechargeable Battery Replacement: passo 4, immagine 1 di 1
    • Remove the battery from its compartment by sliding it out away from the drone.
Conclusione
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 550
