Salta al contenuto principale
Protocol Dronium Two HD Camera Replacement
Cosa ti serve
  1. Protocol Dronium Two HD Camera Replacement, Landing Gear: passo 1, immagine 1 di 1
    • Turn device off by moving the selector switch to the left.
  2. Protocol Dronium Two HD Camera Replacement: passo 2, immagine 1 di 2 Protocol Dronium Two HD Camera Replacement: passo 2, immagine 2 di 2
    • Place one hand on the drone and carefully remove the landing gear with the other hand.
    • Be gentle as to not break off the studs on the landing gear.
  3. Protocol Dronium Two HD Camera Replacement, HD Camera: passo 3, immagine 1 di 2 Protocol Dronium Two HD Camera Replacement, HD Camera: passo 3, immagine 2 di 2
    • Use the fine edged plastic opening tool to pull up one side of the plug, and then the other, until it comes loose.
  4. Protocol Dronium Two HD Camera Replacement: passo 4, immagine 1 di 2 Protocol Dronium Two HD Camera Replacement: passo 4, immagine 2 di 2
    • Push the battery cover away from the drone and carefully open it up.
  5. Protocol Dronium Two HD Camera Replacement: passo 5, immagine 1 di 2 Protocol Dronium Two HD Camera Replacement: passo 5, immagine 2 di 2
    • Carefully remove the two Phillips 5.35 mm screws holding the camera to the battery cover.
  6. Protocol Dronium Two HD Camera Replacement: passo 6, immagine 1 di 1
    • Close the battery cover by pulling it towards you. Then, gently pull the camera towards you, freeing it from the battery cover.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 280
