Salta al contenuto principale
Proscan Tablet Touch Screen Replacement
Cosa ti serve
  1. Proscan Tablet Touch Screen Replacement, Touch Screen: passo 1, immagine 1 di 1
    • Tools necessary for task.
    • Starting from the left to right
    • Metal Spudyer
    • Plastic opening tool
    • Precision tweezer
    • Point pen tool
    • Driver with bit size J0
  2. Proscan Tablet Touch Screen Replacement: passo 2, immagine 1 di 1
    • The backing of the tablet is fastened by simply snapping it in. Using the metal opening tool, pry between the plastic backing and the edge, but do not remove it yet. Work your way around until you have them separated.
  3. Proscan Tablet Touch Screen Replacement: passo 3, immagine 1 di 1
    • Once you have finished going around the edges of the tablet, look inside.
  4. Proscan Tablet Touch Screen Replacement: passo 4, immagine 1 di 1
    • You will notice two wires still connecting the backing to the computer. These are for the speakers.
  5. Proscan Tablet Touch Screen Replacement: passo 5, immagine 1 di 1
    • You can remove the speakers with your hands to free the backing completely.
  6. Proscan Tablet Touch Screen Replacement: passo 6, immagine 1 di 1
    • Next the following highlighted spots are screws. These screws must be loosened to separate the motherboard and digitizer from the outer glass components. Remember lefty loosely, righty tighty. All screws were placed on a magnet board to ensure they did not roll away
  7. Proscan Tablet Touch Screen Replacement: passo 7, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • There is some tape wire that links the screen to the grey digitizer. This can be gently pulled apart by the tweezers
  8. Proscan Tablet Touch Screen Replacement: passo 8, immagine 1 di 1
    • Next focus on the camera and volume components along the edges highlighted here. The screws have already been taken out, gently pull them off.
  9. Proscan Tablet Touch Screen Replacement: passo 9, immagine 1 di 1
    • Gently lift the green motherboard from the grey digitizer to ensure that all screws have been removed. The only connection remaining should be a tape wire to the battery.
  10. Proscan Tablet Touch Screen Replacement: passo 10, immagine 1 di 1
    • The last step is to remove the grey digitizer from the screen entirely. Note that the blue battery and green motherboard will still be attached, move them as one part
Conclusione
Altre 3 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 5,976
