Salta al contenuto principale
Proscan Tablet Camera Replacement
Cosa ti serve
  1. Proscan Tablet Camera Replacement, Camera: passo 1, immagine 1 di 1
    • Tools necessary for task. Starting from the left to right Metal Spudyer Plastic opening tool Precision tweezer Point pen tool Driver with bit size J0
  2. Proscan Tablet Camera Replacement: passo 2, immagine 1 di 1
    • The backing of the tablet is fastened by simply snapping it in. Using the metal opening tool, pry between the plastic backing and the edge, but do not remove it yet. Work your way around until you have them separated.
  3. Proscan Tablet Camera Replacement: passo 3, immagine 1 di 1
    • Once you have finished going around the edges of the tablet, look inside.
  4. Proscan Tablet Camera Replacement: passo 4, immagine 1 di 1
    • You can directly locate and remove the camera component in the corner. Simply unscrew the piece and gently remove the tape wire.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 387
