Salta al contenuto principale
ProntoTec Axius Camera Replacement
Cosa ti serve
    1. ProntoTec Axius Camera Replacement, Camera: passo 1, immagine 1 di 1
      • Make sure the device is completely turned off before you begging taking it apart to avoid electrocution risks.
      • Place the tablet face-up on a flat table.
      Chiedi a FixBot
      Aggiungi Commento
    2. ProntoTec Axius Camera Replacement: passo 2, immagine 1 di 1
      • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
      • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
      Chiedi a FixBot
      Aggiungi Commento
    3. ProntoTec Axius Camera Replacement: passo 3, immagine 1 di 1
      • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
      • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
      Chiedi a FixBot
      Aggiungi Commento
    4. ProntoTec Axius Camera Replacement: passo 4, immagine 1 di 1
      • Remove only the yellow tape that touches the battery.
      • Be careful not to cut or damage the wires (red and black) that are under the yellow tape.'
      Chiedi a FixBot
      Aggiungi Commento
    5. ProntoTec Axius Camera Replacement: passo 5, immagine 1 di 2 ProntoTec Axius Camera Replacement: passo 5, immagine 2 di 2
      • Use the flat end of the spudger to gently pry the top left corner battery from the back of the screen in order to access the camera.
      Chiedi a FixBot
      Aggiungi Commento
    6. ProntoTec Axius Camera Replacement: passo 6, immagine 1 di 3 ProntoTec Axius Camera Replacement: passo 6, immagine 2 di 3 ProntoTec Axius Camera Replacement: passo 6, immagine 3 di 3
      • Use the spudger to lift the black clamp as shown in the photo to disconnect the camera from the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    7. ProntoTec Axius Camera Replacement: passo 7, immagine 1 di 2 ProntoTec Axius Camera Replacement: passo 7, immagine 2 di 2
      • Disconet the camera from the motherboard.
      • Pull the camera from the back of the screen.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
UMass Dartmouth, Team 5-3, Martin Fall 2016 Membro di UMass Dartmouth, Team 5-3, Martin Fall 2016
UMASSD-MARTIN-F16S5G3
3 Membri
10 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 10
Ultimi 30 giorni: 33
Tutti i Tempi: 462
