Introduzione
A damaged spring can lead to issues with the toaster lever being fully locked in and released. When the lever is released it should be able to move freely in an upward direction. When the lever is being pushed down, it should move smoothly with slight resistance from the spring.
  1. Make sure that the toaster is unplugged before attempting any sort of disassembly!
    • Make sure that the toaster is unplugged before attempting any sort of disassembly!
  2. Grip the black plastic lever nub firmly and carefully remove it from the metal lever. Use one hand to hold the toaster in place while you pull the lever nub with the other. If this is the first time detaching this piece, it will take some effort to remove. Be careful as pulling too hard can cause damage to the inner lever mechanism.
    • Grip the black plastic lever nub firmly and carefully remove it from the metal lever. Use one hand to hold the toaster in place while you pull the lever nub with the other.
    • If this is the first time detaching this piece, it will take some effort to remove. Be careful as pulling too hard can cause damage to the inner lever mechanism.
  3. Flipping the toaster upside down, use a T7 Torx Screwdriver to remove the four 10mm screws that keep the outer shell attached. Flip the toaster back over and slide off the shell making sure to slip the toaster lever (now without the black plastic nub) through the lever opening in the shell. The outer shell should now only be connected by its internal wiring.
    • Flipping the toaster upside down, use a T7 Torx Screwdriver to remove the four 10mm screws that keep the outer shell attached.
    • Flip the toaster back over and slide off the shell making sure to slip the toaster lever (now without the black plastic nub) through the lever opening in the shell.
    • The outer shell should now only be connected by its internal wiring.
  4. Kit di riparazione per Android
    Un nuovo schermo o una nuova batteria sono ad un kit di distanza.
    Acquista ora
    Acquista ora
  5. Locate and remove the two 8mm screws that attach the circuit board (located inside of the shell) from the shell itself using the Phillips #2 screwdriver. The shell should now be completely separated from the rest of the toaster.
    • Locate and remove the two 8mm screws that attach the circuit board (located inside of the shell) from the shell itself using the Phillips #2 screwdriver.
    • The shell should now be completely separated from the rest of the toaster.
  6. Locate your damaged spring that holds the toaster lever in place.
    • Locate your damaged spring that holds the toaster lever in place.
    • The spring in the picture is not damaged.
  7. Disconnect the bottom part of the damaged spring from the lever first. Then disconnect the top part of the damaged spring from the chassis.
    • Disconnect the bottom part of the damaged spring from the lever first.
    • Then disconnect the top part of the damaged spring from the chassis.
  8. Attach the new spring in the same spots that the damaged spring was removed from. Check to make sure that the new spring allows the lever to move down with slight resistance and that it pops back up after being released.
    • Attach the new spring in the same spots that the damaged spring was removed from.
    • Check to make sure that the new spring allows the lever to move down with slight resistance and that it pops back up after being released.
Conclusione
David Acosta
Membro da: 24/01/2014
101 Reputation
1 Guida realizzata
Cal Poly, Team 10-36, Maness Winter 2014 Membro di Cal Poly, Team 10-36, Maness Winter 2014
CPSU-MANESS-W14S10G36
4 Membri
5 Guide realizzate
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 9
All Time: 992
