Introduzione
Broken toaster levers often occur as a result of the accumulation of crumbs or simply, because of age. This guide’s purpose is to demonstrate how to replace a broken toaster lever on a on a Proctor Silex 4 Slice Toaster (Model 24215). This guide will also instruct you on how to properly disassemble your Proctor Silex toaster.
Prior to beginning the guide, make sure that the toaster is unplugged from the power source and it is properly cooled off if it has been used recently.
Cosa ti serve
Unplug the toaster before disassembly.
If this does not work, locate the white plastic wedges (on both sides), otherwise known as the extension, which forces the contact between the lever and the electromagnet.
Using a tweezer, align the contact points so that the two pieces make are able to make contact.
Also, make sure that the four screws you did not remove from the toaster are screwed into both of the plastic wedges on each side of the toaster (2 screws per wedge). A loose wedge could be the cause of a broken lever.
