ProScan PLT7223G Motherboard Replacement
Introduzione
Vai al passo 1If your device isn't working and other troubleshooting methods have failed, or a component of the motherboard has failed, use this guide to replace the motherboard and make your device functional again.
Cosa ti serve
Remove both 4 mm screws from the top of the tablet using a PH00 screw driver.
Altre 2 persone hanno completato questa guida.
Un commento
Once the motherboard is out, what do you do ? Where do I go? More information would be appreciated.
