Salta al contenuto principale
ProScan PLT7223G Front Facing Camera Replacement
Cosa ti serve
  1. ProScan PLT7223G Front Facing Camera Replacement, Front Facing Camera: passo 1, immagine 1 di 1
    • Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
  2. ProScan PLT7223G Front Facing Camera Replacement: passo 2, immagine 1 di 1
    • Use the blue plastic opening tool to pry open the tablet.
    • You will hear popping sounds. That's okay.
    • Be careful when using the blue plastic opening tool on the side of the device near the speakers, as there is a wire here that connects the speakers to the motherboard.
  3. ProScan PLT7223G Front Facing Camera Replacement: passo 3, immagine 1 di 1
    • With a spudger, flip up the ZIF connector that connects the camera's ribbon cable to the motherboard. This will release the ribbon cable.
  4. ProScan PLT7223G Front Facing Camera Replacement: passo 4, immagine 1 di 1
    • Remove the black tape holding down the ribbon cable.
  5. ProScan PLT7223G Front Facing Camera Replacement: passo 5, immagine 1 di 1
    • Remove camera.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 327
