Salta al contenuto principale
ProScan PLT7223G Battery Replacement
Cosa ti serve
  1. ProScan PLT7223G Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
  2. ProScan PLT7223G Battery Replacement: passo 2, immagine 1 di 1
    • Use the blue plastic opening tool to pry open the tablet.
    • You will hear popping sounds. That's okay.
    • Be careful when using the blue plastic opening tool on the side of the device near the speakers, as there is a wire here that connects the speakers to the motherboard.
  3. ProScan PLT7223G Battery Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Use a soldering tool and tweezers to remove the black and red wire from the motherboard.
    • Be sure to pay attention to where each wire goes so that you attach them in the correct order when reassembling the device.
    • Soldering tool will get hot, handle with care.
  4. ProScan PLT7223G Battery Replacement: passo 4, immagine 1 di 1
    • Use a spudger to remove the black tape from the battery.
  5. ProScan PLT7223G Battery Replacement: passo 5, immagine 1 di 1
    • Using the flat end of a spudger, carefully separate the battery from the base of the device.
    • There is an adhesive holding the charger in place.
Conclusione
Altre 3 persone hanno completato questa guida.
2Commenti sulla guida
what is the number of the replacement battery??
florcomm - Replica
How will I know if my proscan tablet battery is no good once I remove it
Genica Harmon - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 4,506
