Salta al contenuto principale
ProScan PLT7050 Motherboard Replacement
Cosa ti serve
  1. ProScan PLT7050 Motherboard Replacement, Open Device: passo 1, immagine 1 di 1
    • Make sure device is unplugged and turned off while working on the device.
    • Remove 2 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
  2. ProScan PLT7050 Motherboard Replacement: passo 2, immagine 1 di 1
    • Use the plastic opening tools to pry the back of the tablet open.
    • You may need to slide the tool along the sides of the device to get it to open. You might hear some popping noises, it is okay.
    • May be helpful if you start by the microSD slot.
  3. ProScan PLT7050 Motherboard Replacement, Motherboard: passo 3, immagine 1 di 2 ProScan PLT7050 Motherboard Replacement, Motherboard: passo 3, immagine 2 di 2
    • Remove the 3 black pieces of tape from the device.
    • Remove the 5 yellow pieces of tape from the device.
  4. ProScan PLT7050 Motherboard Replacement: passo 4, immagine 1 di 2 ProScan PLT7050 Motherboard Replacement: passo 4, immagine 2 di 2
    • Use the soldering tool to remove the 3 wires from the mother board to the battery (black, red, gray).
    • Soldering tool will get hot.
  5. ProScan PLT7050 Motherboard Replacement: passo 5, immagine 1 di 2 ProScan PLT7050 Motherboard Replacement: passo 5, immagine 2 di 2
    • Remove the speaker wires from the motherboard with the soldering tool.
  6. ProScan PLT7050 Motherboard Replacement: passo 6, immagine 1 di 1
    • Remove 3 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
  7. ProScan PLT7050 Motherboard Replacement: passo 7, immagine 1 di 3 ProScan PLT7050 Motherboard Replacement: passo 7, immagine 2 di 3 ProScan PLT7050 Motherboard Replacement: passo 7, immagine 3 di 3
    • Use the plastic opening tool to pop open all 3 ZIF connector tabs connected to the motherboard.
    • Remove each ribbon from the ZIF connector port.
  8. ProScan PLT7050 Motherboard Replacement: passo 8, immagine 1 di 1
    • Lift the motherboard off the device taking care to pull the ports out of the casing.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 449
