Salta al contenuto principale
ProScan PLT7050 Camera Replacement
Cosa ti serve
  1. ProScan PLT7050 Camera Replacement, Open Device: passo 1, immagine 1 di 1
    • Make sure device is unplugged and turned off while working on the device.
    • Remove 2 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
  2. ProScan PLT7050 Camera Replacement: passo 2, immagine 1 di 1
    • Use the plastic opening tools to pry the back of the tablet open.
    • You may need to slide the tool along the sides of the device to get it to open. You might hear some popping noises, it is okay.
    • May be helpful if you start by the microSD slot.
  3. ProScan PLT7050 Camera Replacement, Camera: passo 3, immagine 1 di 1
    • Remove the black tape carefully.
  4. ProScan PLT7050 Camera Replacement: passo 4, immagine 1 di 1
    • Use the plastic opening tool to open the ZIF connector tab to release the camera's ribbon cable.
  5. ProScan PLT7050 Camera Replacement: passo 5, immagine 1 di 1
    • Remove the camera's ribbon cable.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 189
