Salta al contenuto principale
ProScan PLT7050 Battery Replacement
Cosa ti serve
  1. ProScan PLT7050 Battery Replacement, Open Device: passo 1, immagine 1 di 1
    • Make sure device is unplugged and turned off while working on the device.
    • Remove 2 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
  2. ProScan PLT7050 Battery Replacement: passo 2, immagine 1 di 1
    • Use the plastic opening tools to pry the back of the tablet open.
    • You may need to slide the tool along the sides of the device to get it to open. You might hear some popping noises, it is okay.
    • May be helpful if you start by the microSD slot.
  3. ProScan PLT7050 Battery Replacement, Battery: passo 3, immagine 1 di 2 ProScan PLT7050 Battery Replacement, Battery: passo 3, immagine 2 di 2
    • Use the soldering tool to remove the wires from the motherboard. (Black and Red)
    • The soldering tool is hot.
    • Take note of where the wires are located.
  4. ProScan PLT7050 Battery Replacement: passo 4, immagine 1 di 2 ProScan PLT7050 Battery Replacement: passo 4, immagine 2 di 2
    • Remove the black tape from the battery.
    • Remove the three pieces of yellow tape from the battery.
  5. ProScan PLT7050 Battery Replacement: passo 5, immagine 1 di 1
    • Use the plastic opening tool to pry the battery from the device as it is attached by an adhesive.
    • Do not proceed if corrosion and/or swelling of the battery is visible.
Conclusione
Altre 4 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,163
