Salta al contenuto principale
PowerShot G7 X Mark II LCD Screen Replacement
Cosa ti serve
  1. PowerShot G7 X Mark II LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 1
    • Use a Philips #000 screwdriver to remove the three 2mm screws on the bottom of the LCD screen.
  2. PowerShot G7 X Mark II LCD Screen Replacement: passo 2, immagine 1 di 1
    • Tilt the LCD screen all the way up and use a Phillips #000 screwdriver to remove the three 4mm screws from the back of the LCD screen.
  3. PowerShot G7 X Mark II LCD Screen Replacement, Remove back panel from LCD screen: passo 3, immagine 1 di 1
    • Use a spudger tool to release the ribbon cable from the ZIF connector.
    • The cable is thin and delicate. Detach with care.
    • Gently pry off the screen until the double-sided tape behind the back panel gives in.
  4. PowerShot G7 X Mark II LCD Screen Replacement: passo 4, immagine 1 di 1
    • The screen is detached and can now be replaced.
Conclusione
Altre 5 persone hanno completato questa guida.
Brandon
Membro da: 02/15/17
644 Reputazione
4 Guide realizzate
USF Tampa, Team 12-3, Eyestone Spring 2017 Membro di USF Tampa, Team 12-3, Eyestone Spring 2017
USFT-EYESTONE-S17S12G3
3 Membri
4 Guide realizzate
5Commenti sulla guida
Are there any problems with the replacement screen? It’s a touch screen, just making sure the functionality of the screen is still intact.
Andrew Baez - Replica
These directions do not give enough information. The screed is glued into the frame. The replacement parts do not come with the circuit board.
alan saltus - Replica
Did you successfully replace the screen? I took off the screws, and got to the detaching the wire stage but then discovered as you said “the glue”. Any further insight would be appreciated!
rachelkernali -
My G7X lost one of the 2 screws holding the screen: do you know where I can find them?
paolofarinella - Replica
on ebay or amazon. you can order it
nicole -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 36
Ultimi 30 Giorni: 154
Tutti i Tempi: 10,874
