Introduzione
This guide will show you how to replace the Front Panel and Focus Ring of the camera if it is damaged or if the lens has gotten dirt lodged in it.
Cosa ti serve
Use a Phillips #000 screwdriver to remove four 4mm screws from the NFC panel cover on the bottom of the camera.
Use a Phillips #000 screwdriver to remove two 3mm screws on the left and one 5mm screw on the right from the front panel.
Altre 2 persone hanno completato questa guida.
2 Commenti
Please give instructions how to disassemble the flash and replace the flash capacitor. Thank you very much
