Salta al contenuto principale
PowerShot G7 X Mark II Front Cover Replacement
Cosa ti serve
  1. PowerShot G7 X Mark II Front Cover Replacement, Top Cover Button Panel: passo 1, immagine 1 di 2 PowerShot G7 X Mark II Front Cover Replacement, Top Cover Button Panel: passo 1, immagine 2 di 2
    • Use a Phillips #000 screwdriver to remove four 4mm screws from the NFC panel cover on the bottom of the camera.
  2. PowerShot G7 X Mark II Front Cover Replacement: passo 2, immagine 1 di 2 PowerShot G7 X Mark II Front Cover Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #000 screwdriver to remove five screws from under the LCD screen:
    • Three 2.4 mm screws
    • Two 3 mm screws
  3. PowerShot G7 X Mark II Front Cover Replacement: passo 3, immagine 1 di 1
    • Use a Phillips #000 screwdriver to remove two 3mm screws on the left of the camera.
  4. PowerShot G7 X Mark II Front Cover Replacement: passo 4, immagine 1 di 2 PowerShot G7 X Mark II Front Cover Replacement: passo 4, immagine 2 di 2
    • Use a Phillips #000 screwdriver to remove one 3mm and one 4mm screw on the surface of the right face of the camera, and one under the USB/HDMI cover.
  5. PowerShot G7 X Mark II Front Cover Replacement: passo 5, immagine 1 di 2 PowerShot G7 X Mark II Front Cover Replacement: passo 5, immagine 2 di 2
    • Carefully remove the back cover off of the camera by hand, minding the ribbon cable attached to the camera body. If the cover does not detach, use a spudger to pry it off.
    • Use the spudger tool to open the ZIF connector attaching the ribbon cable to the camera body.
  6. PowerShot G7 X Mark II Front Cover Replacement: passo 6, immagine 1 di 2 PowerShot G7 X Mark II Front Cover Replacement: passo 6, immagine 2 di 2
    • Use a Phillips #000 screwdriver to remove two 3mm screws on the pop-up flash.
  7. PowerShot G7 X Mark II Front Cover Replacement: passo 7, immagine 1 di 2 PowerShot G7 X Mark II Front Cover Replacement: passo 7, immagine 2 di 2
    • Use a Phillips #000 screwdriver to remove two 2mm screws attaching the button panel to the camera body.
    • Use a Phillips #000 screwdriver to remove a 3mm screw from beneath the mode dial.
  8. PowerShot G7 X Mark II Front Cover Replacement: passo 8, immagine 1 di 3 PowerShot G7 X Mark II Front Cover Replacement: passo 8, immagine 2 di 3 PowerShot G7 X Mark II Front Cover Replacement: passo 8, immagine 3 di 3
    • Open the battery compartment and remove the battery by flipping the small latch holding it in.
    • Use a Phillips #000 screwdriver to remove one 6mm screw in the bottom of the battery compartment.
  9. PowerShot G7 X Mark II Front Cover Replacement: passo 9, immagine 1 di 2 PowerShot G7 X Mark II Front Cover Replacement: passo 9, immagine 2 di 2
    • Pry the top cover button assembly off of the camera body by detaching clips around the base of it.
  10. PowerShot G7 X Mark II Front Cover Replacement, Front Cover: passo 10, immagine 1 di 1
    • Use a Phillips #000 screwdriver to remove two 3mm screws on the left and one 5mm screw on the right from the front panel.
  11. PowerShot G7 X Mark II Front Cover Replacement: passo 11, immagine 1 di 1
    • Remove the USB/HDMI panel from the right side of the camera.
  12. PowerShot G7 X Mark II Front Cover Replacement: passo 12, immagine 1 di 1
    • Separate the front cover and focus ring assembly from the front of the camera. Use a plastic spudger to detach the ZIF connector holding the ribbon cable connected to the focus assembly.
Conclusione
Altre 2 persone hanno completato questa guida.
Brandon
Membro da: 02/15/17
626 Reputazione
4 Guide realizzate
USF Tampa, Team 12-3, Eyestone Spring 2017 Membro di USF Tampa, Team 12-3, Eyestone Spring 2017
USFT-EYESTONE-S17S12G3
3 Membri
4 Guide realizzate
2 Commenti
thank you so much for the guide!! extremely helpful, clear pictures, and easy to understand instructions.
victoria - Replica
Please give instructions how to disassemble the flash and replace the flash capacitor. Thank you very much
Momchil Panayotov - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 43
Tutti i Tempi: 3,973
