Salta al contenuto principale
PowerLead Puto PLD003 Zoom Button Replacement
Cosa ti serve
  1. PowerLead Puto PLD003 Zoom Button Replacement, Side Panel: passo 1, immagine 1 di 1
    • Slide the battery eject button open to release the battery door.
  2. PowerLead Puto PLD003 Zoom Button Replacement: passo 2, immagine 1 di 1
    • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
  3. PowerLead Puto PLD003 Zoom Button Replacement: passo 3, immagine 1 di 1
    • Rotate the camera so that the underside is facing up.
    • Remove the four 5 mm Phillips #1 screws.
  4. PowerLead Puto PLD003 Zoom Button Replacement: passo 4, immagine 1 di 1
    • Place the camera on a flat surface, with its underside facing you.
    • Gently pull up on the side panel to remove it from the camera.
  5. PowerLead Puto PLD003 Zoom Button Replacement, Zoom Button: passo 5, immagine 1 di 2 PowerLead Puto PLD003 Zoom Button Replacement, Zoom Button: passo 5, immagine 2 di 2
    • Remove the 4 mm Phillips #1 screws holding the weight.
    • Remove the weight.
  6. PowerLead Puto PLD003 Zoom Button Replacement: passo 6, immagine 1 di 1
    • Remove the two 4 mm Phillips #1 screws holding the back panel in place.
  7. PowerLead Puto PLD003 Zoom Button Replacement: passo 7, immagine 1 di 1
    • Apply pressure to the back panel, pulling away from the camera to remove it.
  8. PowerLead Puto PLD003 Zoom Button Replacement: passo 8, immagine 1 di 2 PowerLead Puto PLD003 Zoom Button Replacement: passo 8, immagine 2 di 2
    • Remove the final 4 mm Phillips #1 screw holding the screen in place.
    • This screw is very small and hard to see.
  9. PowerLead Puto PLD003 Zoom Button Replacement: passo 9, immagine 1 di 1
    • Carefully apply pressure away from the camera to the screen to detach it from the body.
    • The white cord should still be connected to the body.
    • OPTIONAL: Remove the screen to make accessing the zoom button easier.
  10. PowerLead Puto PLD003 Zoom Button Replacement: passo 10, immagine 1 di 1
    • Remove the three 4 mm Phillips #1 screws holding the top panel in place.
  11. PowerLead Puto PLD003 Zoom Button Replacement: passo 11, immagine 1 di 2 PowerLead Puto PLD003 Zoom Button Replacement: passo 11, immagine 2 di 2
    • Push upward on the top panel to remove it from the body of the camera.
  12. PowerLead Puto PLD003 Zoom Button Replacement: passo 12, immagine 1 di 2 PowerLead Puto PLD003 Zoom Button Replacement: passo 12, immagine 2 di 2
    • Remove the two 4 mm Phillips #1 screws holding the circuit board in place.
    • Do not remove the silver screws.
  13. PowerLead Puto PLD003 Zoom Button Replacement: passo 13, immagine 1 di 1
    • Lift the circuit board out of the plastic casing.
    • Gently pull on the zoom button to remove it from the circuit board.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 268
