Salta al contenuto principale
PowerLead Puto PLD003 Back Buttons Replacement
Cosa ti serve
  1. PowerLead Puto PLD003 Back Buttons Replacement, Side Panel: passo 1, immagine 1 di 1
    • Slide the battery eject button open to release the battery door.
  2. PowerLead Puto PLD003 Back Buttons Replacement: passo 2, immagine 1 di 1
    • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
  3. PowerLead Puto PLD003 Back Buttons Replacement: passo 3, immagine 1 di 1
    • Rotate the camera so that the underside is facing up.
    • Remove the four 5 mm Phillips #1 screws.
  4. PowerLead Puto PLD003 Back Buttons Replacement: passo 4, immagine 1 di 1
    • Place the camera on a flat surface, with its underside facing you.
    • Gently pull up on the side panel to remove it from the camera.
  5. PowerLead Puto PLD003 Back Buttons Replacement, Back Buttons: passo 5, immagine 1 di 2 PowerLead Puto PLD003 Back Buttons Replacement, Back Buttons: passo 5, immagine 2 di 2
    • Remove the three 4 mm Phillips #1 screws holding the weight.
    • Remove the weight.
  6. PowerLead Puto PLD003 Back Buttons Replacement: passo 6, immagine 1 di 1
    • Remove the two 4 mm Phillips #1 screws holding the back panel in place.
  7. PowerLead Puto PLD003 Back Buttons Replacement: passo 7, immagine 1 di 1
    • Apply pressure to the back panel, away from the camera to remove.
  8. PowerLead Puto PLD003 Back Buttons Replacement: passo 8, immagine 1 di 2 PowerLead Puto PLD003 Back Buttons Replacement: passo 8, immagine 2 di 2
    • Place the back panel so the buttons are facing down and the circuit board is facing up.
    • Remove the three 4 mm Phillips #1 screws holding the circuit board in place.
  9. PowerLead Puto PLD003 Back Buttons Replacement: passo 9, immagine 1 di 1
    • Set aside the circuit board.
    • These nubs are what is currently holding the buttons in place.
    • Carefully apply pressure and remove the set of buttons from the nubs.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 155
