Salta al contenuto principale
PowerBook G4 Titanium Onyx DVD Drive Replacement
Cosa ti serve
  1. PowerBook G4 Titanium Onyx DVD Drive Replacement, Keyboard: passo 1, immagine 1 di 1
    • Remove the battery.
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  2. PowerBook G4 Titanium Onyx DVD Drive Replacement: passo 2, immagine 1 di 1
    • Rest the keyboard face down on the trackpad area.
    • Disconnect the keyboard connector from the logic board.
  3. PowerBook G4 Titanium Onyx DVD Drive Replacement: passo 3, immagine 1 di 1
    • Your laptop should look approximately like this.
  4. PowerBook G4 Titanium Onyx DVD Drive Replacement, RAM: passo 4, immagine 1 di 1
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to ÒpopÓ up.
    • Pull the RAM chip out.
    • Repeat this process if a second RAM chip is installed.
    Don't forget to spread the brackets on the sides apart to release the chips.
    Calion - Replica
    yes, I missed that and the little notches that hold the upper RAM broke.
    Jamba - Replica
    • Turn the G4 over.
    • Remove the eight T8 Torx screws from the lower case.
  5. PowerBook G4 Titanium Onyx DVD Drive Replacement: passo 6, immagine 1 di 1
    • Using your thumbs, slide the lower case away from you.
    • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
  6. PowerBook G4 Titanium Onyx DVD Drive Replacement: passo 7, immagine 1 di 1
  7. PowerBook G4 Titanium Onyx DVD Drive Replacement, Airport Card: passo 8, immagine 1 di 1
    • Skip this step if your computer does not have an Airport card.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
    • Disconnect the antenna cable from the left side of the Airport card.
    I'm not sure what the point is for this step. This helped not at all in getting the drive out. Also, the cable is taped down, and must be untaped before the card will come out.
    Calion - Replica
  8. PowerBook G4 Titanium Onyx DVD Drive Replacement, Hard Drive: passo 9, immagine 1 di 1
    • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger, removing tape as necessary.
  9. PowerBook G4 Titanium Onyx DVD Drive Replacement: passo 10, immagine 1 di 1
    • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
  10. PowerBook G4 Titanium Onyx DVD Drive Replacement: passo 11, immagine 1 di 1
    • Remove the hard drive by gently grasping the orange ribbon cable and lifting the left edge up and out of the computer.
    • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
  11. PowerBook G4 Titanium Onyx DVD Drive Replacement: passo 12, immagine 1 di 1
  12. PowerBook G4 Titanium Onyx DVD Drive Replacement, DVD Drive: passo 13, immagine 1 di 1
    • If your G4 has a CD-RW or Combo drive, the pictures in the following steps will not exactly match your computer.
    • Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over, making sure the DVD drive doesn't fall out. Place the computer on the cloth.
  13. PowerBook G4 Titanium Onyx DVD Drive Replacement: passo 14, immagine 1 di 1
    • Bend the silver metal EMI clip so that it is vertical. This part may fall out after removing the DVD drive.
    • The EMI clip is not essential for reassembling the computer. If the clip falls out, don't worry about putting it back in.
    You don't actually have to bend the EMI clip. You can use a 2mm or smaller slotted screwdriver to pry the clip up and out.
    Sugar Fish - Replica
    Sugar Fish was dead-on about using a 2mm slotted screwdriver! But I must say, I’m not sure why this step is here at this point in the guide. I went ahead and removed the clip back in Step 4, after having removed the RAM, with no adverse issues.
    Michael Triplett - Replica
  14. PowerBook G4 Titanium Onyx DVD Drive Replacement: passo 15, immagine 1 di 1
    • Turn the G4 over.
    • Disconnect the orange DVD ribbon cable from the logic board using a spudger or the tip of your finger
  15. PowerBook G4 Titanium Onyx DVD Drive Replacement: passo 16, immagine 1 di 1
    • Remove the DVD drive by lifting the right edge up and out of the computer.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
Conclusione
Altre 7 persone hanno completato questa guida.
Documenti Allegati
iRobot
Membro da: 09/24/09
1 Reputazione
636 Guide realizzate
Un commento
I need the connector 4 this ... Can't find it anywhere
PeNn N RoMe - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 9,160
