Introduzione
Upgrade your RAM for an instant increase in speed.
Use your thumbs to push the two battery retaining tabs away from the battery.
  • Use your thumbs to push the two battery retaining tabs away from the battery.
  • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Aggiungi Commento
Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
  • Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
Aggiungi Commento
  • Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
Aggiungi Commento
  • Use your fingertips to pull the two RAM arms away from the sides of the RAM chip. The chip should pop up slightly.
  • Pull the RAM chip away from its socket and remove it from the logic board.
  • Repeat this process for the other RAM chip, if present.
Aggiungi Commento
Conclusione
Altre 24 persone hanno completato questa guida.
Documenti Allegati
What is the maximum ram that I can bump up this system to?
Legendary Ocelot - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 7,760
