Introduzione
Replace your AirPort/Bluetooth board to regain wireless connectivity.
Use your thumbs to push the two battery retaining tabs away from the battery.
  • Use your thumbs to push the two battery retaining tabs away from the battery.
  • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Aggiungi Commento
Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
  • Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
Aggiungi Commento
  • Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
Aggiungi Commento
  • Remove the following ten screws:
    • Two 14.7 mm shouldered Phillips.
    • Three 12.3 mm Phillips.
    • One 3.8 mm T8 Torx.
    • One 6.8 mm T8 Torx.
    • Three 1.3 mm Phillips.
Aggiungi Commento
  • The ZIF cable is located underneath the bottom RAM slot. If your PowerBook has both RAM slots occupied, make sure to remove the RAM chip.
  • Use your fingernails to separate the ZIF cable lock away from its socket. (Move the two brown bits down 1mm)
  • The ZIF cable lock will move about a millimeter away from the socket before it stops (see picture 2). Do not try to remove the ZIF cable lock.
The ZIF cable locks are the little grey pieces seen on the cable-side ends of the white bar. They will slide, as per detailed picture, toward the cable.
web - Replica
  • Use the tip of a spudger to slide the trackpad ribbon cable out of its socket.
Aggiungi Commento
  • Remove the four 3.4 mm Phillips screws from the PC card side of the PowerBook.
  • When replacing these screws, you must reinstall each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
Aggiungi Commento
  • Remove the four 3.4 mm Phillips screws from the DVI connector side of the PowerBook.
  • During reassembly, make sure to reinstall the two screws on the right into their appropriate locations, and not the DVI port anchor holes.
Aggiungi Commento
  • Depress the display latch release button and open your display.
Aggiungi Commento
  • Starting near the display, lift the upper case straight up off the lower case, minding any cables that may get caught.
Sometimes the "tags"/"lugs" that are around the edge of the top & bottom frame, be careful not to bend them as when putting back the covers they will not merge. I used a screwdriver to poke through the hole the screw was supposed go in & push against the "inside nut" to let the tag from the top slide down between the 2 tags. The "inside nut" is like the one right next to the ribbon cable as shown in Dia.14. The screws are from Dia. 7&8.
harry allcock - Replica
in what direction does one move the ZIF cable lock? what/where is its socket?
Ian - Replica
When putting the machine back together (following steps in reverse), make sure the trackpad ribbon cable comes through the underside of the computer — there is an opening that the cable needs to go through and you will want to “thread the needle” with the cable before securing the upper case again.
Tim - Replica
  • If necessary, peel back the strip of aluminum tape covering the modem cable.
Aggiungi Commento
  • Use the flat end of a spudger to pry the modem cable connector up off the modem.
Aggiungi Commento
  • Disconnect the RJ-11 cable from the modem.
Aggiungi Commento
  • Use a 4 mm nut driver to remove the two nuts securing the modem to the PC card cage.
Aggiungi Commento
  • Lift the modem straight up off the studs on the PC card cage.
Aggiungi Commento
  • Use the flat end of a spudger to pry the hard drive cable connector up off the logic board.
  • Bend the hard drive cable away from the PC card cage, giving yourself room to remove it.
Aggiungi Commento
  • Use the flat end of a spudger to pry the PC card cage connector up off the logic board.
Aggiungi Commento
  • Use the tip of a spudger to peel back the small strip of copper tape off the edge of the PC card cage near the side of the lower case.
Aggiungi Commento
  • Remove the four Phillips screws (2- 4 mm & 2 -6.8 mm ) securing the PC card cage to the lower case.
  • The two longer 6.8 mm shouldered screws belong in the end of the PC card cage closest to the logic board.
Aggiungi Commento
  • Lift the PC card cage by its center piece and maneuver it out of the lower case.
Aggiungi Commento
  • When reinstalling your PC card cage, be sure to insert the post sticking up from the PC card release button into the hole in the black plastic release mechanism on the PC card cage.
Aggiungi Commento
  • Use the flat end of a spudger to pry the ribbon cable connector up off the AirPort/Bluetooth board.
Aggiungi Commento
  • Remove the single 2.1 mm Phillips screw securing the AirPort/Bluetooth bracket to the lower case.
  • It is possible to remove the AirPort/Bluetooth board without removing this screw. Alternatively use the sharp end of a spudger to press the metal pressure connector (shown in orange) down through the hole in the AirPort/Bluetooth board, being careful to not break it off when prying the board up in the next step.
Aggiungi Commento
  • Use the flat end of a spudger to pry the AirPort/Bluetooth board up off the adhesive securing it to the lower case.
Aggiungi Commento
  • If necessary, remove the piece of tape and EMI foam covering the AirPort/Bluetooth antennas.
  • Don't forget to reapply this piece of tape during reassembly. It insulates the bare antenna connectors from the metal PC card cage.
Aggiungi Commento
  • Use the flat end of a spudger to pry both antenna connectors up off the AirPort/Bluetooth board.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Documenti Allegati
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 5,824
