Salta al contenuto principale
PowerBook G4 Aluminum 17" 1-1.67 GHz Speakers Replacement
Cosa ti serve
  1. PowerBook G4 Aluminum 17" 1-1.67 GHz Speakers Replacement, Battery: passo 1, immagine 1 di 1
    • Orient the computer so that the side with the line of screws on it is away from you.
    • Use your thumbs to push both battery release tabs away so that the edge of the battery lifts up.
    • Lift the battery out of the computer.
    Chiedi a FixBot
    Aggiungi Commento
  2. PowerBook G4 Aluminum 17" 1-1.67 GHz Speakers Replacement, Upper Case: passo 2, immagine 1 di 1
    • Remove the three identical Phillips screws from the memory door.
    Chiedi a FixBot
    Aggiungi Commento
  3. PowerBook G4 Aluminum 17" 1-1.67 GHz Speakers Replacement: passo 3, immagine 1 di 1
    • Lift the memory door up enough so that you can get a grip on it, and slide it toward you, pulling it away from the casing.
    Chiedi a FixBot
    Aggiungi Commento
  4. PowerBook G4 Aluminum 17" 1-1.67 GHz Speakers Replacement: passo 4, immagine 1 di 1
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the chip directly out from its connectors. If there is a second RAM chip installed, pop it out in the same manner.
    Chiedi a FixBot
    Aggiungi Commento
    • This is a diagram of the trackpad ribbon clamp connector you will disconnect in the next step.
    • 1) With your fingernails, grasp the locking bar on either side slide it a small amount (about 1/16" or 2 mm) towards the battery.
    • 2) After disengaging the locking bar, slide the cable out of the connector.
    Chiedi a FixBot
    Aggiungi Commento
  5. PowerBook G4 Aluminum 17" 1-1.67 GHz Speakers Replacement: passo 6, immagine 1 di 1
    • For this step, you only need to move the connector about 2 mm. Pulling too hard or too far will damage the connector.
    • Loosen the trackpad connector by pulling the locking bar toward the battery housing, using the tips of your fingers.
    • Slide the trackpad cable out of the loosened connector.
    • When reattaching the trackpad ribbon cable, make sure that the orange cable is slid into the connector above the locking bar.
    • Note: When reassembling the case, the trackpad cable can get stuck below the slot to the motherboard. It's possible to nudge it out slowly by gently prodding it on either side with a small screwdriver. You don't need to use much force to do this. Eventually it will just pop back out and you can reconnect as per the instructions above. Also, note that the locking bar comes loose so if you see a little piece of plastic lying around when reassembling, that's what it is. :)
    Chiedi a FixBot
    Aggiungi Commento
  6. PowerBook G4 Aluminum 17" 1-1.67 GHz Speakers Replacement: passo 7, immagine 1 di 1
    • Remove the following 10 screws from the bottom case:
    • Three 1.7 mm Phillips from the front edge of the battery compartment.
    • One 3.9 mm T8 Torx to the right of the memory card.
    • One 6.9 mm T8 Torx at the left edge of the memory compartment.
    • Three 12.4 mm fully threaded Phillips from the center of the row of screws along the back edge of the case.
    • Two 15.1 mm 2.5 mm threaded Phillips, one from either end of the row of screws along the back edge of the case.
    Chiedi a FixBot
    Aggiungi Commento
    • Turn the computer over and rotate it so that the DVI port faces you.
    • Remove the four identical Phillips screws spread along this edge of the case.
    Chiedi a FixBot
    Aggiungi Commento
    • Turn the computer 180 degrees so that the power receptacle faces you, and remove the four Phillips screws (identical to those in the last step).
    Chiedi a FixBot
    Aggiungi Commento
  7. PowerBook G4 Aluminum 17" 1-1.67 GHz Speakers Replacement: passo 10, immagine 1 di 1
    • Open the computer and turn it so that the screen faces you.
    • Pull the upper case off, lifting from the back, and working around the edges.
    Chiedi a FixBot
    Aggiungi Commento
  8. PowerBook G4 Aluminum 17" 1-1.67 GHz Speakers Replacement: passo 11, immagine 1 di 1
    • Use a spudger to loosen the casing if it sticks.
    • Once the casing is entirely free, lift it off of the computer.
    Chiedi a FixBot
    Aggiungi Commento
  9. PowerBook G4 Aluminum 17" 1-1.67 GHz Speakers Replacement, Bluetooth: passo 12, immagine 1 di 1
    • Use the method described in the step for disconnecting the keyboard ribbon to loosen the connector on the DC-In board.
    • Pull the cable free of the loosened connector.
    Chiedi a FixBot
    Aggiungi Commento
  10. PowerBook G4 Aluminum 17" 1-1.67 GHz Speakers Replacement: passo 13, immagine 1 di 1
    • Remove the single Phillips screw from the Bluetooth board.
    Chiedi a FixBot
    Aggiungi Commento
  11. PowerBook G4 Aluminum 17" 1-1.67 GHz Speakers Replacement: passo 14, immagine 1 di 1
    • Lift the Bluetooth board partially out of the computer and disconnect the attached antenna cable.
    Chiedi a FixBot
    Aggiungi Commento
  12. PowerBook G4 Aluminum 17" 1-1.67 GHz Speakers Replacement, Speakers: passo 15, immagine 1 di 1
    • Disconnect the black speaker cable from the sound board.
    Chiedi a FixBot
    Aggiungi Commento
  13. PowerBook G4 Aluminum 17" 1-1.67 GHz Speakers Replacement: passo 16, immagine 1 di 1
    • Remove the single T8 Torx screw from the left speaker assembly.
    Chiedi a FixBot
    Aggiungi Commento
  14. PowerBook G4 Aluminum 17" 1-1.67 GHz Speakers Replacement: passo 17, immagine 1 di 1
    • Disconnect the orange DC-In cable from the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  15. PowerBook G4 Aluminum 17" 1-1.67 GHz Speakers Replacement: passo 18, immagine 1 di 1
    • Deroute the cables from the right side of the speaker and lift it off of the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  16. PowerBook G4 Aluminum 17" 1-1.67 GHz Speakers Replacement: passo 19, immagine 1 di 1
    • Remove the single T8 Torx screw from the right speaker assembly.
    Chiedi a FixBot
    Aggiungi Commento
  17. PowerBook G4 Aluminum 17" 1-1.67 GHz Speakers Replacement: passo 20, immagine 1 di 1
    • Deroute the display data cable from the left side of the speaker and pull the speaker assembly off the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  18. PowerBook G4 Aluminum 17" 1-1.67 GHz Speakers Replacement: passo 21, immagine 1 di 1
    • In order to disconnect the speaker cable from the front edge of the logic board, you must disconnect the sound cable, the optical drive cable, and the PRAM battery cable.
    Chiedi a FixBot
    Aggiungi Commento
  19. PowerBook G4 Aluminum 17" 1-1.67 GHz Speakers Replacement: passo 22, immagine 1 di 1
    • Deroute the speaker cable from the front edge of the logic board.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Documenti allegati
iRobot
Membro da: 09/24/09
1 Reputazione
636 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 10
Ultimi 30 giorni: 47
Tutti i Tempi: 7,566
