Salta al contenuto principale
PowerBook G4 Aluminum 17" 1-1.67 GHz PC Card Cage Replacement
Cosa ti serve
    1. PowerBook G4 Aluminum 17" 1-1.67 GHz PC Card Cage Replacement, Battery: passo 1, immagine 1 di 1
      • Orient the computer so that the side with the line of screws on it is away from you.
      • Use your thumbs to push both battery release tabs away so that the edge of the battery lifts up.
      • Lift the battery out of the computer.
      Chiedi a FixBot
      Aggiungi Commento
    1. PowerBook G4 Aluminum 17" 1-1.67 GHz PC Card Cage Replacement, Upper Case: passo 2, immagine 1 di 1
      • Remove the three identical Phillips screws from the memory door.
      Chiedi a FixBot
      Aggiungi Commento
    2. PowerBook G4 Aluminum 17" 1-1.67 GHz PC Card Cage Replacement: passo 3, immagine 1 di 1
      • Lift the memory door up enough so that you can get a grip on it, and slide it toward you, pulling it away from the casing.
      Chiedi a FixBot
      Aggiungi Commento
    3. PowerBook G4 Aluminum 17" 1-1.67 GHz PC Card Cage Replacement: passo 4, immagine 1 di 1
      • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
      • Pull the chip directly out from its connectors. If there is a second RAM chip installed, pop it out in the same manner.
      Chiedi a FixBot
      Aggiungi Commento
      • This is a diagram of the trackpad ribbon clamp connector you will disconnect in the next step.
      • 1) With your fingernails, grasp the locking bar on either side slide it a small amount (about 1/16" or 2 mm) towards the battery.
      • 2) After disengaging the locking bar, slide the cable out of the connector.
      Chiedi a FixBot
      Aggiungi Commento
    4. PowerBook G4 Aluminum 17" 1-1.67 GHz PC Card Cage Replacement: passo 6, immagine 1 di 1
      • For this step, you only need to move the connector about 2 mm. Pulling too hard or too far will damage the connector.
      • Loosen the trackpad connector by pulling the locking bar toward the battery housing, using the tips of your fingers.
      • Slide the trackpad cable out of the loosened connector.
      • When reattaching the trackpad ribbon cable, make sure that the orange cable is slid into the connector above the locking bar.
      • Note: When reassembling the case, the trackpad cable can get stuck below the slot to the motherboard. It's possible to nudge it out slowly by gently prodding it on either side with a small screwdriver. You don't need to use much force to do this. Eventually it will just pop back out and you can reconnect as per the instructions above. Also, note that the locking bar comes loose so if you see a little piece of plastic lying around when reassembling, that's what it is. :)
      Chiedi a FixBot
      Aggiungi Commento
    5. PowerBook G4 Aluminum 17" 1-1.67 GHz PC Card Cage Replacement: passo 7, immagine 1 di 1
      • Remove the following 10 screws from the bottom case:
      • Three 1.7 mm Phillips from the front edge of the battery compartment.
      • One 3.9 mm T8 Torx to the right of the memory card.
      • One 6.9 mm T8 Torx at the left edge of the memory compartment.
      • Three 12.4 mm fully threaded Phillips from the center of the row of screws along the back edge of the case.
      • Two 15.1 mm 2.5 mm threaded Phillips, one from either end of the row of screws along the back edge of the case.
      Chiedi a FixBot
      Aggiungi Commento
      • Turn the computer over and rotate it so that the DVI port faces you.
      • Remove the four identical Phillips screws spread along this edge of the case.
      Chiedi a FixBot
      Aggiungi Commento
      • Turn the computer 180 degrees so that the power receptacle faces you, and remove the four Phillips screws (identical to those in the last step).
      Chiedi a FixBot
      Aggiungi Commento
    6. PowerBook G4 Aluminum 17" 1-1.67 GHz PC Card Cage Replacement: passo 10, immagine 1 di 1
      • Open the computer and turn it so that the screen faces you.
      • Pull the upper case off, lifting from the back, and working around the edges.
      Chiedi a FixBot
      Aggiungi Commento
    7. PowerBook G4 Aluminum 17" 1-1.67 GHz PC Card Cage Replacement: passo 11, immagine 1 di 1
      • Use a spudger to loosen the casing if it sticks.
      • Once the casing is entirely free, lift it off of the computer.
      Chiedi a FixBot
      Aggiungi Commento
    1. PowerBook G4 Aluminum 17" 1-1.67 GHz PC Card Cage Replacement, Modem: passo 12, immagine 1 di 1
      • Disconnect the orange ribbon from the right side of the modem, removing tape as necessary.
      Chiedi a FixBot
      Aggiungi Commento
    2. PowerBook G4 Aluminum 17" 1-1.67 GHz PC Card Cage Replacement: passo 13, immagine 1 di 1
      • Remove the three 4 mm hex nuts using a nut driver or needle-nosed pliers.
      Chiedi a FixBot
      Aggiungi Commento
    3. PowerBook G4 Aluminum 17" 1-1.67 GHz PC Card Cage Replacement: passo 14, immagine 1 di 1
      • Lift the modem partially out of the computer, disconnecting the modem cable before pulling it entirely away.
      Chiedi a FixBot
      Aggiungi Commento
    1. PowerBook G4 Aluminum 17" 1-1.67 GHz PC Card Cage Replacement, PC Card Cage: passo 15, immagine 1 di 1
      • Place the computer on edge (with the display open).
      • Remove the black bumper and disconnect the Airport Extreme cable beneath it.
      Chiedi a FixBot
      Aggiungi Commento
    2. PowerBook G4 Aluminum 17" 1-1.67 GHz PC Card Cage Replacement: passo 16, immagine 1 di 1
      • Back inside the computer, disconnect the Airport antenna cable at the gold connector, making sure you pull only on the gold metal portion of the connector.
      Chiedi a FixBot
      Aggiungi Commento
    3. PowerBook G4 Aluminum 17" 1-1.67 GHz PC Card Cage Replacement: passo 17, immagine 1 di 1
      • If you have not already done so, disconnect the hard drive ribbon and PC card cage ribbon from the left side of the logic board.
      Chiedi a FixBot
      Aggiungi Commento
    4. PowerBook G4 Aluminum 17" 1-1.67 GHz PC Card Cage Replacement: passo 18, immagine 1 di 1
      • Remove the four Phillips screws from the corners of the PC card cage.
      • The longer screws go on the right side of the PC card cage.
      Chiedi a FixBot
      Aggiungi Commento
    5. PowerBook G4 Aluminum 17" 1-1.67 GHz PC Card Cage Replacement: passo 19, immagine 1 di 1
      • In the following step, the connector you disconnected from the underside of the logic board may catch as you're pulling the card cage out. Of course, the same issue may arise when putting a card cage back into the computer.
      • Hold the PC card cage on the left side and pull it out of the computer.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Documenti allegati
iRobot
Membro da: 09/24/09
1 Reputazione
632 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 23
Ultimi 30 giorni: 72
Tutti i Tempi: 5,163
