Introduzione
Replacing this keyboard is easy and takes only a few minutes.
Strumenti
Nessun attrezzo specificato.
Ricambi
Remove both expansion bay modules using the levers on the front of the computer.
Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
Pull the tabs toward yourself and the keyboard will pop up.
Altre 8 persone hanno completato questa guida.
