Salta al contenuto principale
PowerBook G3 Lombard PRAM Battery Replacement
Cosa ti serve
  1. PowerBook G3 Lombard PRAM Battery Replacement, Keyboard: passo 1, immagine 1 di 1
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
  2. PowerBook G3 Lombard PRAM Battery Replacement: passo 2, immagine 1 di 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
  3. PowerBook G3 Lombard PRAM Battery Replacement: passo 3, immagine 1 di 1
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
  4. PowerBook G3 Lombard PRAM Battery Replacement, PRAM Battery: passo 4, immagine 1 di 1
    • Pull the battery cable directly up from the logic board.
  5. PowerBook G3 Lombard PRAM Battery Replacement: passo 5, immagine 1 di 1
    • Remove the battery from its holder by pulling up and to the left.
Conclusione
Altre 5 persone hanno completato questa guida.
Documenti Allegati
iRobot
Membro da: 09/24/09
1 Reputazione
636 Guide realizzate
2 Commenti
Step 4, 5 and 6 are useless for changing the PRAM battery..
Godzil - Replica
Seems the step I was referring to are no longer there!
Godzil -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 15
Tutti i Tempi: 10,920
