Cosa ti serve
Use a heat gun with temperature set to 140 F for about 2-3 minutes and heat the casing where it attaches together as seen in the picture.
After heating for about 2-3 minutes, separate the housing using a pry tool as seen in the pictures.
Use a soldering iron to desolder battery connection to remove battery and replace with new one.
Altre 13 persone hanno completato questa guida.
5 Commenti
If you need this part you can order it here
My battery only was connected by two wires. Is that a newer edition of the Powerbeats than this one? Has Apple changed their wiring?
Where can I get the batteries? Is it available besides beats showroom?
My bettry is too good work but tha wireis want to b change
Plzz tel me how I can change tha wire of my power beats
