Salta al contenuto principale
PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement
Cosa ti serve
  1. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Locate Battery Side: passo 1, immagine 1 di 2 PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Locate Battery Side: passo 1, immagine 2 di 2
    • Battery is located in the right side headphone housing.
  2. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Heat Battery Housing: passo 2, immagine 1 di 1
    • Use a heat gun with temperature set to 140 F for about 2-3 minutes and heat the casing where it attaches together as seen in the picture.
  3. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove Housing: passo 3, immagine 1 di 3 PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove Housing: passo 3, immagine 2 di 3 PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove Housing: passo 3, immagine 3 di 3
    • After heating for about 2-3 minutes, separate the housing using a pry tool as seen in the pictures.
  4. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove/Replace Battery: passo 4, immagine 1 di 1
    • Use a soldering iron to desolder battery connection to remove battery and replace with new one.
Conclusione
Altre 13 persone hanno completato questa guida.
Faizan Naveed
Membro da: 04/12/17
3.294 Reputazione
8 Guide realizzate
Mobile Device Repair Factory Membro di Mobile Device Repair Factory
Business
1 Membro
16 Guide realizzate
5 Commenti
If you need this part you can order it here
https://www.joesge.com/products/powerbea...
JoesGE - Replica
My battery only was connected by two wires. Is that a newer edition of the Powerbeats than this one? Has Apple changed their wiring?
Andrew Manwaring - Replica
Where can I get the batteries? Is it available besides beats showroom?
Tara Chandrabura - Replica
My bettry is too good work but tha wireis want to b change
Asoo Malik - Replica
Plzz tel me how I can change tha wire of my power beats
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 103
Tutti i Tempi: 28,896
