Salta al contenuto principale
PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement
Cosa ti serve
  1. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Locate Battery.: passo 1, immagine 1 di 1
    • The battery is located inside the right side ear piece.
  2. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Heat Right Side.: passo 2, immagine 1 di 1
    • Heat the right side gently at 140 F for about 3 minutes.
    • Do not over heat or it will melt the housing.
  3. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Remove Battery Cover/Casing: passo 3, immagine 1 di 2 PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Remove Battery Cover/Casing: passo 3, immagine 2 di 2
    • After heating, gently remove the cover/casing as shown in the picture.
    • Take your time and re-heat if cover/casing does not remove smoothly.
  4. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Desolder & Replace Battery: passo 4, immagine 1 di 1
    • Desolder battery using soldering iron and replace with replacement battery.
  5. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Reattach Battery Cover/Casing: passo 5, immagine 1 di 2 PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Reattach Battery Cover/Casing: passo 5, immagine 2 di 2
    • After battery is replaced, apply super glue to the border of the inside of the battery cover/casing and put it back in place.
    • Use small clamps/binder clip to hold the housing in place while the super glue dries up.
Conclusione
Altre 9 persone hanno completato questa guida.
Faizan Naveed
Membro da: 04/12/17
3.294 Reputazione
8 Guide realizzate
Mobile Device Repair Factory Membro di Mobile Device Repair Factory
Business
1 Membro
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 55
Tutti i Tempi: 26,862
