Salta al contenuto principale
PowerA Spectra Infinity Enhanced Vibration Motors Replacement
Cosa ti serve
  1. PowerA Spectra Infinity Enhanced Vibration Motors Replacement, Motherboard: passo 1, immagine 1 di 2 PowerA Spectra Infinity Enhanced Vibration Motors Replacement, Motherboard: passo 1, immagine 2 di 2
    • Flip the controller so the back is facing up.
  2. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: passo 2, immagine 1 di 1
    • Remove the eight 10 mm screws from the back of the controller using a Phillips #0 screwdriver.
  3. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: passo 3, immagine 1 di 2 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: passo 3, immagine 2 di 2
    • Unlock the trigger locks before removing the backplate.
    • This will make taking the plate off easier.
    • Use your fingers and carefully remove the backplate.
  4. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: passo 4, immagine 1 di 1
    • Remove the two 10 mm screws connecting the motherboard to the faceplate using a Phillips #0 screwdriver.
  5. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: passo 5, immagine 1 di 2 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: passo 5, immagine 2 di 2
    • Use your hand to separate the motherboard from the face plate.
  6. PowerA Spectra Infinity Enhanced Vibration Motors Replacement, Vibration Motors: passo 6, immagine 1 di 2 PowerA Spectra Infinity Enhanced Vibration Motors Replacement, Vibration Motors: passo 6, immagine 2 di 2
    • Remove the four 7.9 mm screws using a Phillips #0 screwdriver.
  7. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: passo 7, immagine 1 di 2 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: passo 7, immagine 2 di 2
    • Use tweezers to unplug the small plug connecting the motors to the motherboard.
    • A firm grip may be necessary for this step.
  8. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: passo 8, immagine 1 di 3 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: passo 8, immagine 2 di 3 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: passo 8, immagine 3 di 3
    • Remove the completely freed vibration motor from the motherboard.
Conclusione
Altre 2 persone hanno completato questa guida.
Kevyn Jorge
Membro da: 03/22/24
1.018 Reputazione
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 27
Tutti i Tempi: 353
