Introduzione
Analog stick is one of the main component of the controller, which enables us to move or change camera angle in a game. The following steps will show you how to replace it.
  1. Remove the (9) nine 9.2mm screws with a JIS #1 screwdriver. Remove the two bottom plastic grip covers. Remove the two bottom plastic grip covers.
    • Remove the (9) nine 9.2mm screws with a JIS #1 screwdriver.
    • Remove the two bottom plastic grip covers.
  2. Remove the (2) two 9.2mm screws with a JIS #1 screwdriver. Remove the back cover of the controller.
    • Remove the (2) two 9.2mm screws with a JIS #1 screwdriver.
    • Remove the back cover of the controller.
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Remove the (5) five 9.2mm screws with a JIS #1 screwdriver. Lift the motherboard and let it hang. Lift the motherboard and let it hang.
    • Remove the (5) five 9.2mm screws with a JIS #1 screwdriver.
    • Lift the motherboard and let it hang.
  5. Remove the (4) four 9.2mm screws that are holding the motherboard to the controller. Remove the motherboard.
    • Remove the (4) four 9.2mm screws that are holding the motherboard to the controller.
    • Remove the motherboard.
  6. Use the tweezers to unclip the four metal teeth of the analog stick. Use the soldering iron to desolder the analog stick sensor module from the back of the motherboard.
    • Use the tweezers to unclip the four metal teeth of the analog stick.
    • Use the soldering iron to desolder the analog stick sensor module from the back of the motherboard.
    • Place the new analog stick sensor module and solder it back.
Conclusione
Marjan Mehedi
Membro da: 27/09/2017
119 Reputazione
1 Guida realizzata
USF Tampa, Team S14-G4, Boczar Fall 2017 Membro di USF Tampa, Team S14-G4, Boczar Fall 2017
USFT-BOCZAR-F17S14G4
4 Membri
5 Guide realizzate
Hi I’m looking those analog stick but I’m only finding the plastic and they are to big they are called different or something ?
Jose nobkes - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 111
Tutti i Tempi: 1,680
