Salta al contenuto principale
PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement
Cosa ti serve
  1. PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement, Motherboard: passo 1, immagine 1 di 3 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement, Motherboard: passo 1, immagine 2 di 3 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement, Motherboard: passo 1, immagine 3 di 3
    • Remove the battery cover by pressing down on the lever located on the top of the cover.
    • Apply pressure until it clicks out of place, and pull it off.
  2. PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement: passo 2, immagine 1 di 1
    • Remove all eight screws using the J0 screwdriver.
  3. PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement: passo 3, immagine 1 di 2 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement: passo 3, immagine 2 di 2
    • Insert the iFixit opening tool into the seam and gently pry the cover plate up.
    • Remove the cover plate once it is loosened.
  4. PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement: passo 4, immagine 1 di 3 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement: passo 4, immagine 2 di 3 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement: passo 4, immagine 3 di 3
    • Remove all three screws securing the motherboard using the J00 screwdriver.
    • Remove the motherboard.
  5. PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement, L and R Thumbsticks Covers: passo 5, immagine 1 di 3 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement, L and R Thumbsticks Covers: passo 5, immagine 2 di 3 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement, L and R Thumbsticks Covers: passo 5, immagine 3 di 3
    • Pull the L and R stick covers out of the socket.
Conclusione
Altre 13 persone hanno completato questa guida.
USF Tampa, Team S1-G5, Leahy Fall 2019 Membro di USF Tampa, Team S1-G5, Leahy Fall 2019
USFT-LEAHY-F19S1G5
3 Membri
11 Guide realizzate
21Commenti sulla guida
My controllers are drifting, What can i do after getting the joystick of to fix that.
MilesGDC - Replica
i dont know i cleaned using plush sticks ( that usually go to ears that one ) i used that and isopropacol alcohoc 90%
it works for 2 weeks ( on me ) and now my Right analog stick is too Loose to wiggle there
BrunoS -
Where can I get replacement thumbsticks for this controller? Are they the same as the Switch Pro Controllers?
engelgott0972 - Replica
i need replacement joy-sticks too
BrunoS -
I need a link for the thumbsticks too. Cant seem to find them anywhere and PowerA does no sell them nor is willing to help.
Brandon Kohl -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 39
Ultimi 30 Giorni: 197
Tutti i Tempi: 16,125
