Salta al contenuto principale
PowerA Enhanced Wireless Controller Directional Pad Replacement
Cosa ti serve
  1. PowerA Enhanced Wireless Controller Directional Pad Replacement, Motherboard: passo 1, immagine 1 di 3 PowerA Enhanced Wireless Controller Directional Pad Replacement, Motherboard: passo 1, immagine 2 di 3 PowerA Enhanced Wireless Controller Directional Pad Replacement, Motherboard: passo 1, immagine 3 di 3
    • Remove the battery cover by pressing down on the lever located on the top of the cover.
    • Apply pressure until it clicks out of place, and pull it off.
  2. PowerA Enhanced Wireless Controller Directional Pad Replacement: passo 2, immagine 1 di 1
    • Remove all eight screws using the J0 screwdriver.
  3. PowerA Enhanced Wireless Controller Directional Pad Replacement: passo 3, immagine 1 di 2 PowerA Enhanced Wireless Controller Directional Pad Replacement: passo 3, immagine 2 di 2
    • Insert the iFixit opening tool into the seam and gently pry the cover plate up.
    • Remove the cover plate once it is loosened.
  4. PowerA Enhanced Wireless Controller Directional Pad Replacement: passo 4, immagine 1 di 3 PowerA Enhanced Wireless Controller Directional Pad Replacement: passo 4, immagine 2 di 3 PowerA Enhanced Wireless Controller Directional Pad Replacement: passo 4, immagine 3 di 3
    • Remove all three screws securing the motherboard using the J00 screwdriver.
    • Remove the motherboard.
  5. PowerA Enhanced Wireless Controller Directional Pad Replacement, Directional Pad: passo 5, immagine 1 di 3 PowerA Enhanced Wireless Controller Directional Pad Replacement, Directional Pad: passo 5, immagine 2 di 3 PowerA Enhanced Wireless Controller Directional Pad Replacement, Directional Pad: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Use the rubber tweezers to grab the center of the directional pad and pull it out by pinching its center.
Conclusione
USF Tampa, Team S1-G5, Leahy Fall 2019 Membro di USF Tampa, Team S1-G5, Leahy Fall 2019
USFT-LEAHY-F19S1G5
3 Membri
11 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,281
