Introduzione
The PowerA Enhanced Wired Controller for Nintendo Switch is a budget-friendly Switch and PC compatible controller with no rumble support but which comes in lots of designs.
Cosa ti serve
A cheaper alternative to the official Nintendo version, without a built-in battery and rumble motors it feels quite light
Start by flipping over the controller the controller to find eight #0 Phillips screws
The front shell has mouldings for rumble motors but the motherboard does not have any apparent connections for them
Unplug the two shoulder button connectors
Remove the two screws that hold the motherboard in place
The front shell is pretty standard with removable buttons
The rear programmable buttons are moulded into the shell so are not replaceable
There are two more Phillips screws holding the button assembly together
Nothing holds the L and R bumpers but the ZL and ZR triggers are on a hinge
Small plastic posts hold the ZL and ZR triggers in place. Gently pry the triggers off the posts using a plastic pry tool or fingernails. These are easy to break so be gentle here. The elastomer underneath is held on by little posts that stick through the plastic. Removing them is easy but pushing them back in is a challenge
The elastomers are held in with little posts that go through the board. The sticks are soldered so are not easy to remove
Altre 2 persone hanno completato questa guida.
2Commenti sulla guida
My rubber pads have worn out. I've been looking for replacement pads, but no one seems to sell them.
You can probably order rubber pads for a ps4 controller and cut them to fit. Not ideal but they are easy to find online and relatively cheap
