Salta al contenuto principale
Power rack&pinion steering Replacement
Cosa ti serve
    1. Power rack&pinion steering Replacement, Power rack&pinion steering: passo 1, immagine 1 di 3 Power rack&pinion steering Replacement, Power rack&pinion steering: passo 1, immagine 2 di 3 Power rack&pinion steering Replacement, Power rack&pinion steering: passo 1, immagine 3 di 3
      • From inside the vehicle on drivers side use a 11mm socket to remove the three nuts that secure the boot to the firewall
      • Using a 10mm sockstRemove the two pinch bolts form the shaft and remove shaft & boot
      Chiedi a FixBot
      Aggiungi Commento
      • raise and support the front of the vehicle
      • place the jack stands in the reinforced area just behind the engine cradle
      • Use a 19mm socket remove both front tires
      • remove the cotter pin and castle nuts from tie rod ends
      • remove tie rod ends from steering knuckle
      Chiedi a FixBot
      Aggiungi Commento
      • remove the two Nuts and Bolts that secured flex pipe to the y pipe
      • From inside the engine compartment remove the three nuts that secure the strut to the strut Tower on both sides
      • place a floor jack with a short piece of 2 by 6 under the transmission pan
      • Raise Jack until it just starts to lift the transmission
      Chiedi a FixBot
      Aggiungi Commento
      • loosen the two front bolts of the subframe but do not remove
      • remove the two Bolts from the rear of the subframe
      • Slowly lower jack in till you have about 4 inches of clearance
      • Remove the two nuts that secure the steering rack to the subframe
      • Lift the steering rack up until the bolts clear rotate rack to gain access to the hose fittings and remove
      • Slide rack to the left and remove thru drivers side wheel well
      Chiedi a FixBot
      Aggiungi Commento
      • Transfer any parts needed from old rack to the new rack
      • Install in reverse order
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Brian Robinson
Membro da: 03/10/16
128 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 21
Ultimi 30 giorni: 93
Tutti i Tempi: 2,561
