Salta al contenuto principale
Power Macintosh G3 Blue and White RAM Replacement
Cosa ti serve
  1. Power Macintosh G3 Blue and White RAM Replacement, RAM: passo 1, immagine 1 di 1
    • Unfortunately, I am unable to provide OG content for this step due to my PowerMac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Lift the latch on the right side panel to reveal the internals of the Power Mac.
    • If you are doing this on a hard surface I highly suggest you put a mat down between the door and the ground to prevent scratches.
  2. Power Macintosh G3 Blue and White RAM Replacement: passo 2, immagine 1 di 1
    • Push the white tabs next to where your RAM is located away form the RAM chip itself.
    • The RAM chips should move up a tad and become somewhat loose.
    • Your RAM configuration may vary. This process is done the exact same way no matter what your RAM placement looks like.
  3. Power Macintosh G3 Blue and White RAM Replacement: passo 3, immagine 1 di 2 Power Macintosh G3 Blue and White RAM Replacement: passo 3, immagine 2 di 2
    • Pull the RAM chips out of the RAM slots.
    • That's all folks! That wasn't too hard, was it?
    • Second image: RAM remains
Conclusione
Altre 2 persone hanno completato questa guida.
[deleted]
Membro da: 08/28/18
27.571 Reputazione
21 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 15
Ultimi 7 Giorni: 52
Ultimi 30 Giorni: 172
Tutti i Tempi: 1,465
