Salta al contenuto principale
Introduzione
I wasn’t able to find a replacement modem assembly online so you are on your own for that part.
Parti
Nessuna parte specificata.
  1. Remove the Phillips #1 screw circled in the picture. Set it aside for re-assembly.
    • Remove the Phillips #1 screw circled in the picture. Set it aside for re-assembly.
  2. Unfortunately, I am unable to provide OG content for this step due to my Power Mac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Unfortunately, I am unable to provide OG content for this step due to my Power Mac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Lift the latch on the right side panel to reveal the internals.
    • If you are doing this on a hard surface I highly suggest you put a mat down between the door and the ground to prevent scratches.
  3. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  4. Remove the single Phillips #1 screw circled in the picture.
    • Remove the single Phillips #1 screw circled in the picture.
    • I apologize for the lack of picture quality. The only camera and lighting I had were my iPhone X´s camera and a table lamp. Lol!
  5. Disconnect the modem’s flex cable from the connector  on the logic board.
    • Disconnect the modem’s flex cable from the connector on the logic board.
    • Lift the modem assembly out of it´s place on the logic board.
Conclusione
Aaron Cooke
Membro da: 28/08/2018
16.959 Reputazione
22 Guide realizzate
NIWOTech Membro di NIWOTech
Community
0 Membri
0 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 67
