Salta al contenuto principale
Power Macintosh G3 Blue and White Graphics Card Replacement
Cosa ti serve
  1. Power Macintosh G3 Blue and White Graphics Card Replacement, Graphics Card: passo 1, immagine 1 di 1
    • Unfortunately, I am unable to provide OG content for this step due to my PowerMac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Lift the latch on the right side panel to reveal the internals.
    • If you are doing this on a hard surface I highly suggest you put a mat down between the door and the ground to prevent scratches.
  2. Power Macintosh G3 Blue and White Graphics Card Replacement: passo 2, immagine 1 di 2 Power Macintosh G3 Blue and White Graphics Card Replacement: passo 2, immagine 2 di 2
    • Remove the single Phillips #1 screw circled in the picture. Set it aside for later.
    • The graphics card is outlined in red in the second image, if you are confused on where this is.
  3. Power Macintosh G3 Blue and White Graphics Card Replacement: passo 3, immagine 1 di 1
    • Lift the graphics card straight out of it's PCI slot.
    • Be careful not to lift sideways, you can damage the PCI slot! Try your best to lift the graphics card straight up.
Conclusione
Altre 2 persone hanno completato questa guida.
[deleted]
Membro da: 08/28/18
26.355 Reputazione
21 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,535
