Cosa ti serve
Press the green release button on top of the side access panel.
Pull off the side access panel to get inside the computer.
Unscrew the two Phillips screws holding the hard drive in place.
The hard drive and its carrier should come off together.
Gently pry up the tab on the left side of the floppy drive bezel.
Swing the bezel open.
Remove the bezel from the right edge of the floppy drive.
Using a Phillips screwdriver, remove the two floppy drive shield screws.
Remove the floppy drive shield.
Disconnect the floppy drive cable from the back of the floppy drive.
Slide the floppy drive carrier and drive out of the front of the computer.
Release the three tabs holding the top cover by pushing the front tab toward the back of the unit and the back two tabs toward the front of the unit.
Slide the top cover toward the stationary panel side to remove it from the chassis.
