Salta al contenuto principale
Power Macintosh G3 (Minitower) Hard Drive Assembly Replacement
Cosa ti serve
    • Press the green release button on top of the side access panel.
    • Pull off the side access panel to get inside the computer.
    • When putting the side access panel back on, make sure that the bottom of the panel lines up with the rail on the bottom, and that the chassis is locked with the green latches.
    • Unscrew the two Phillips screws holding the hard drive in place.
    • The hard drive and its carrier should come off together.
    • Unplug the IDE and Molex cables from the hard drive.
    • Be sure to be careful when removing the IDE cable so as to not damage the pins on the hard drive. (Instead of yanking it, pry it off from side to side.)
Conclusione
LeoI07
Membro da: 06/10/21
1.573 Reputazione
17 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 17
Tutti i Tempi: 429
