Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
This is meant to be a private prereq guide.
Parti
Nessuna parte specificata.
  1. The handle to open your computer is located on top of the right side panel.
    • The handle to open your computer is located on top of the right side panel.
  2. Grab the circular handle and pull outward. Grab the circular handle and pull outward.
    • Grab the circular handle and pull outward.
  3. Your computer is now open and ready for repair.
    • Your computer is now open and ready for repair.
  4. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  5. The optical drive is in the top left corner of the case.
    • The optical drive is in the top left corner of the case.
  6. There are four screws to be removed. The first screw can be seen in the first picture.
    • There are four screws to be removed.
    • The first screw can be seen in the first picture.
    • The remaining three screws can be seen in the second picture.
  7. Remove the optical drive by pulling the drive away from the front of the computer and out.
    • Remove the optical drive by pulling the drive away from the front of the computer and out.
  8. Detach the two cables attached to the back of the drive.
    • Detach the two cables attached to the back of the drive.
    • The flat ribbon cable can be detached by pulling the silver tab. The multicolored cable can be removed by grasping the plastic connector on either side and pulling with substantial force.
Conclusione
Altre 6 persone hanno completato questa guida.
Jacob Garcia
Membro da: 28/01/2010
513 Reputazione
2 Guide realizzate
Cal Poly, Team 14-41, Regan Winter 2010 Membro di Cal Poly, Team 14-41, Regan Winter 2010
CPSU-REGAN-W10S14G41
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 19
Tutti i Tempi: 5,083
