Salta al contenuto principale
Power Mac G4 M5183 Processor Replacement
Cosa ti serve
  1. Power Mac G4 M5183 Processor Replacement, Opening PowerMac G4 M5183 Case: passo 1, immagine 1 di 2 Power Mac G4 M5183 Processor Replacement, Opening PowerMac G4 M5183 Case: passo 1, immagine 2 di 2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Power Mac G4 M5183 Processor Replacement, Heat Sink: passo 2, immagine 1 di 2 Power Mac G4 M5183 Processor Replacement, Heat Sink: passo 2, immagine 2 di 2
    • Use the spudger to pry the clips horizontally off of the heat sink.
    • Fully remove the clips by lifting upwards.
  3. Power Mac G4 M5183 Processor Replacement: passo 3, immagine 1 di 1
    • Remove the heat sink by pulling upwards, off of the logic board.
  4. Power Mac G4 M5183 Processor Replacement, Processor: passo 4, immagine 1 di 2 Power Mac G4 M5183 Processor Replacement, Processor: passo 4, immagine 2 di 2
    • Remove the 3 screws attaching the processor to the logic board using the Phillips #2 screwdriver.
    • Remove processor by pulling vertically upwards.
Linea Traguardo
Altre 13 persone hanno completato questa guida.
Justin Petrilli
Membro da: 01/21/10
3.114 Reputazione
11 Guide realizzate
Cal Poly, Team 13-24, Maness Winter 2010 Membro di Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Membri
25 Guide realizzate
2 Commenti
anyone still sell the replacement processor?
Joseph Cole - Replica
Anyone who has upgraded their CPU’s manage to flash from MacPro1,1 to MacPro2,1? And If so How?
Michael Inman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 29
Tutti i Tempi: 12,069
