Introduzione
This guide details the removal of the main fan from the fan housing.
Cosa ti serve
Pull on outer latch.
Lower door until it is level with your work surface.
Remove the screw from each of the two niches on lower part of fan using the Phillips #1 screwdriver.
To fully remove the fan, unfasten the 4 screws on the front of the bracing using the Phillips #2 screwdriver.
Altre 3 persone hanno completato questa guida.
