Introduzione
This guide will illustrate how to remove the heat sink from your PowerMac.
Parti
Nessuna parte richiesta.
  1. Pull on outer latch. Lower door until it is level with your work surface.
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
    Mai riparato qualcosa? Questo è Genio.
    Condividi la tua storia di riparazione con #ImAGenius
    Siamo tutti Geni
  3. Use the spudger to pry the clips horizontally off of the heat sink. Fully remove the clips by lifting upwards.
    • Use the spudger to pry the clips horizontally off of the heat sink.
    • Fully remove the clips by lifting upwards.
  4. Remove the heat sink by pulling upwards, off of the logic board.
    • Remove the heat sink by pulling upwards, off of the logic board.
Linea Traguardo
Altre 6 persone hanno completato questa guida.
Justin Petrilli
Membro da: 21/01/2010
2.634 Reputazione
11 Guide realizzate
Cal Poly, Team 13-24, Maness Winter 2010 Membro di Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Membri
16 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 5,141
