Salta al contenuto principale
Power Mac G4 Cube Airport Card Replacement
  1. Power Mac G4 Cube Airport Card Replacement, Remove Cube Core: passo 1, immagine 1 di 3 Power Mac G4 Cube Airport Card Replacement, Remove Cube Core: passo 1, immagine 2 di 3 Power Mac G4 Cube Airport Card Replacement, Remove Cube Core: passo 1, immagine 3 di 3
    • Release the handle at the bottom of the Power Mac G4 Cube by pushing it down. Slowly pull out the cube by holding the end of the handle.
    • Watch for any parts that may become entangled with the outer case.
    • Push back the handle after you have taken the core out of the case.
  2. Power Mac G4 Cube Airport Card Replacement, Accessing AirPort Card: passo 2, immagine 1 di 2 Power Mac G4 Cube Airport Card Replacement, Accessing AirPort Card: passo 2, immagine 2 di 2
    • Pull outwards on the antenna cable.
    • The cable should pop out of the card without much force.
    • Pull on the clear tab outwards to remove the existing AirPort card
    • Slide in the new AirPort card.
    • Reconnect the antenna cable.
Conclusione
Altre 8 persone hanno completato questa guida.
Ryan Chun
Membro da: 06/24/10
1.076 Reputazione
7 Guide realizzate
Cal Poly, Team 2-7, Johann Summer 2010 Membro di Cal Poly, Team 2-7, Johann Summer 2010
CPSU-JOHANN-R10S2G7
5 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 23
Tutti i Tempi: 9,848
