Introduzione
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Follow this guide to remove the power cord on an EDCO Floor Stripper model TS8 .75L (2017).
Cosa ti serve
Ensure the machine is unplugged.
Turn the power switch counterclockwise into the OFF position.
Use a Phillips screwdriver to remove the screw from the center of the red on/off knob.
Remove the black plastic cap from the center of the switch assembly.
Use a Phillips screwdriver to remove the four screws securing the upper half of the switch housing to the lower half.
Use a 3/8 inch socket to remove the bolt securing the power cord loom clamp to the switch bracket.
Use a socket to remove the four 11/32 inch nuts from the on/off switch bracket.
Use a flathead screwdriver to remove the screw securing the two green ground wires to the switch housing.
Use a flathead screwdriver to loosen the two screws on the right side of the switch assembly securing the black and white wires from the power cord.
