Salta al contenuto principale
Porter-Cable PC60TAG Power Cord Replacement
Cosa ti serve
  1. Porter-Cable PC60TAG Power Cord Replacement, Power Cord: passo 1, immagine 1 di 1
    • Using the Phillips #2 screwdriver, remove the 3/4" Phillips head screw on the back cover.
    • Unplug the grinder before disassembling.
  2. Porter-Cable PC60TAG Power Cord Replacement: passo 2, immagine 1 di 1
    • Holding the front of the device, carefully slide the back cover over the cord.
  3. Porter-Cable PC60TAG Power Cord Replacement: passo 3, immagine 1 di 1
    • Using the Phillips #2 screwdriver, remove the two 1/2" Phillips head screws securing the cord grip.
  4. Porter-Cable PC60TAG Power Cord Replacement: passo 4, immagine 1 di 1
    • Using the Phillips #2 screwdriver, loosen, but do not remove, the two terminal screws securing the black and white wires from the power cord.
  5. Porter-Cable PC60TAG Power Cord Replacement: passo 5, immagine 1 di 1
    • Careful remove each wire from the power cord from underneath the terminals.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 457
