Salta al contenuto principale
Porter-Cable 382 Sander Pad Replacement
Cosa ti serve
  1. Porter-Cable 382 Sander Pad Replacement, Sander Pad: passo 1, immagine 1 di 1
    • When changing the sander pad, be sure to rotate the sander upside down so the pad and three highlighted screws are facing upward toward you.
    • Once the sander is upside down begin by removing your old sandpaper.
    • Once the sandpaper is removed locate the three screws on your sander pad.
  2. Porter-Cable 382 Sander Pad Replacement: passo 2, immagine 1 di 1
    • Remove the three, (star bolt) screws with the iFixit screw driver with a "T20" head. Be sure to hold the pad of the sander as it will rotate as you try to loosen the screws.
    • Once the screws are removed pull upward toward you and the sander pad will come apart from the device.
Conclusione
Nick O'Sadcia
Membro da: 03/11/16
421 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,779
