Salta al contenuto principale
Porter-Cable 382 On/ Off Switch Replacement
Cosa ti serve
  1. Porter-Cable 382 On/ Off Switch Replacement, On/ Off Switch: passo 1, immagine 1 di 2 Porter-Cable 382 On/ Off Switch Replacement, On/ Off Switch: passo 1, immagine 2 di 2
    • First, locate the three screws on the top of the sander.
    • Using a screw driver with a size T20 star bit, unscrew the screws by turning them to the left.
  2. Porter-Cable 382 On/ Off Switch Replacement: passo 2, immagine 1 di 2 Porter-Cable 382 On/ Off Switch Replacement: passo 2, immagine 2 di 2
    • Locate your on off switch and in order to remove it you must slide it out of its slot.
    • This shouldnt require any special tools, just wiggle the switch up and out.
    • Make sure this is done carefully, the switch is attached to two wires that may break if they are pulled on too hard.
  3. Porter-Cable 382 On/ Off Switch Replacement: passo 3, immagine 1 di 1
    • Using a spudger such as the one shown, carefully pry open the connectors as shown just enough to slide the prongs of the switch out.
    • Once both prongs are open, the on-off switch can be removed freely and replaced with a new switch.
Conclusione
Nick O'Sadcia
Membro da: 03/11/16
448 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 11
Tutti i Tempi: 265
