Salta al contenuto principale
Porter-Cable 382 Fan Replacement
Cosa ti serve
  1. Porter-Cable 382 Fan Replacement, Sander Pad: passo 1, immagine 1 di 1
    • When changing the sander pad, be sure to rotate the sander upside down so the pad and three highlighted screws are facing upward toward you.
    • Once the sander is upside down begin by removing your old sandpaper.
    • Once the sandpaper is removed locate the three screws on your sander pad.
  2. Porter-Cable 382 Fan Replacement: passo 2, immagine 1 di 1
    • Remove the three, (star bolt) screws with the iFixit screw driver with a "T20" head. Be sure to hold the pad of the sander as it will rotate as you try to loosen the screws.
    • Once the screws are removed pull upward toward you and the sander pad will come apart from the device.
  3. Porter-Cable 382 Fan Replacement, Dust Seal/ Break: passo 3, immagine 1 di 1
    • Once the sander pad is removed and the sander is exposed locate the white plastic like circular piece surrounding the outside of the sander.
  4. Porter-Cable 382 Fan Replacement: passo 4, immagine 1 di 2 Porter-Cable 382 Fan Replacement: passo 4, immagine 2 di 2
    • Once you have located the plastic white ring pull up its outer edge as shown. The lip on the inside will bend and be freed from its secured placement.
    • To reassemble, you will have to line up the protruding square with the key slot as shown otherwise your dust seal/ brake will not go back in.
  5. Porter-Cable 382 Fan Replacement, Fan: passo 5, immagine 1 di 2 Porter-Cable 382 Fan Replacement, Fan: passo 5, immagine 2 di 2
    • Once the dust brake/ seal is removed locate the screw in the center of the device holding down the bearing and fan assembly.
    • unscrew this bolt using a T20 star bit and carefully remove the washer and bearing as shown.
  6. Porter-Cable 382 Fan Replacement: passo 6, immagine 1 di 1
    • Next locate the bolts holding down the guard assembly as shown. There will be one bolt on each side, two in total.
    • Using a T15 star bit unscrew these bolts and make sure you keep them in a safe place.
  7. Porter-Cable 382 Fan Replacement: passo 7, immagine 1 di 1
    • Once the two screws are removed locate the o-ring that seals the dust collector to its opening.
    • Very delicately pry the o-ring out of its slot using a nylon spudger or plastic opening tool. Then roll it off of the opening as shown.
  8. Porter-Cable 382 Fan Replacement: passo 8, immagine 1 di 2 Porter-Cable 382 Fan Replacement: passo 8, immagine 2 di 2
    • Now the two guards will come apart as shown, giving you access to the fan.
    • During reassembly, the two guards will line up so that the dust collector opening lines up with the power cord as shown.
  9. Porter-Cable 382 Fan Replacement: passo 9, immagine 1 di 1
    • The fan can then simply be pulled from its axle and be replaced with the fan blades facing up.
Conclusione
Nick O'Sadcia
Membro da: 03/11/16
421 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 309
