Salta al contenuto principale
Porter Cable 690LR Base Latch Replacement
Cosa ti serve
  1. Porter Cable 690LR Base Latch Replacement, Base: passo 1, immagine 1 di 2 Porter Cable 690LR Base Latch Replacement, Base: passo 1, immagine 2 di 2
    • Undo the black latch located on the base of the router by pulling upwards from underneath it.
  2. Porter Cable 690LR Base Latch Replacement: passo 2, immagine 1 di 2 Porter Cable 690LR Base Latch Replacement: passo 2, immagine 2 di 2
    • Twist the base off the router.
    • You may need to jiggle the base of the router slightly.
  3. Porter Cable 690LR Base Latch Replacement, Base Latch: passo 3, immagine 1 di 2 Porter Cable 690LR Base Latch Replacement, Base Latch: passo 3, immagine 2 di 2
    • Locate the 30 mm bolt and nut attaching the latch to the base.
    • Use a wrench to remove the nut attached to the bolt, freeing the latch from the base.
Conclusione
Cal Poly, Team 20-7, Livingston Fall 2016 Membro di Cal Poly, Team 20-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G7
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 249
